yes i am in photoshop in paths but don't see were to save paths at..does this save picture to? ThanksIf you are doing the path in photoshop you need to save the path, then you can edit, save, re-edit that path within the image file multiple times.
ok if i got a straight path not closed when i do the above my image disappears and my straight line closes itself? but on right in the layers i see the full image but on the screen its cut out...with your path selected... choose... Layer, Vector Mask, Current Path.
nothing in the image will change, only how much of it is revealed, and if you delete the mask, there's your image.
SIDE NOTE: some aspect of working with a masked layer can be difficult, so i always duplicate it, preserving the editable mask if i want a layer that i can mess with.
