Perf Vinyl
legacyborn
I have never used Perf Vinyl before.
1. Can it be laminated?
2. How long does the print last if it isnt?
Thanks!
rjssigns
I spray mine(Solvex) with S-W's Kut-in-Klear. We get about 18 months on the ones we send to AZ and CA. East Coast we get 2+ years.
dlndesign
It depends on the usage? Is it long term or short term?
We print perf vinyl for monthly change-outs, we do not laminate.
If its a vehicle, then Id say yes laminate with a Optically clear, and edge seal tape on the edges, you don't want wipers or the rolling up and down of the windows to start peeling it up. I would also cut back 1/8-1/4 inch in on all sides to prevent any peeling.
Jackpine
Ditto.
deadline
Where do you buy your perf and laminate?
+1. You should definitely laminate it if you can. I use Oracal 3675 with the 290-F laminate. Never had a problem with it if it is installed correctly.
