PerfCutContour: How do you do it?
Discussion in 'Roland' started by Riskok, Mar 15, 2010.
  1. Riskok
    Riskok Member
    191
    Mar 7, 2009
    Sweden
    Hello guys
    I would love if some one could share the settings you use when doing this.
    Normal Pressure Length: ?
    Perforation Length: ?
    Perforation Pressure: ?
    The blades and cutting strip is okay if it get bad fast.
    Thanks for all help!!! :thankyou:
    Best regards Patrik the Swede
  2. TheSellOut
    TheSellOut Very Active Member
    1,355
    I only did a perf cut with the Roland technician when he was at my shop, which it worked well.
    The name of the swatch is – PerfCutContour
    Save it as a spot color. You can make it any color you want.
    We had these settings...
    Normal Pressure Length: .060 in
    Perforation Length: 2" in
    Perforation Pressure: 190 gf
  3. Riskok
    Riskok Member
    191
    Mar 7, 2009
    Sweden
    Thanks for your help!
    I got it to work "good" on the second run. It did cut it out but I think I should have a little more pressure to cut even deeper ore harder.
    Do you know what I should change to get that result?
  4. scarface
    scarface Guest
    to make the blade cut deeper it would be the "Force" setting on the Roland.
  5. Riskok
    Riskok Member
    191
    Mar 7, 2009
    Sweden
    I will do that thanks!
    BR Patrik
  6. Skye
    Skye Member
    108
    Feb 22, 2010
    canada
    search
    search die cut and you will find others with experience on this.
