perferated vinyl and getting a brighter look to it
Discussion in 'Digital Printing' started by gabagoo, Jul 11, 2011.
  1. gabagoo
    gabagoo Major Contributor
    5,740
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    Just wondering if a double hit would make perfed vinyl look better or brighter than the typical dull look it has with a single pass?
  2. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    Not neccesarily because of the surface area available for printing. For example, is you print on white media, the color bounces off the white and it appears bold and bright. If yiu print on clear media, the color cannot bounce, therefore it looks washed out. Therefore, the perforated vision media gives you less white surface for the color to bounce.
  3. "Deposit Please"
    "Deposit Please" Active Member
    780
    Sep 17, 2009
    Illinois
    It always will since you lose 50% of the image. They say 60/40 or 70/30 is not recommended for vehicles, but that would be the only way to get more "POP" from perf. I also noticed perf on tinted glass gets more "pop".......it adds more contrast.
  4. 10sacer
    10sacer Active Member
    775
    7
    18
    Apr 30, 2008
    Concord, NC
    Unless its going on a vehicle - use 70/30 perf - more surface area to receive and transmit color.
  5. rwinninger
    rwinninger Member
    39
    Adding contrast also helps
  6. gabagoo
    5,740
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    I was thinking of that and will try it
    thanks
