Perforated vinyl puckering up and causing head strikes
Printed on perforated vinyl with a JV-150. The vinyl puckers up and causes head strikes. I've tried turning the heat way down (around 25 deg C for the 3 areas) and still have a problem. Anyone have an idea?
wleong
On the Mimaki JV-300, you need to adjust the head height to high by moving out the print carriage. There’s a lever on the carriage to adjust the head. It is enough to enable you to print on mesh banner material. You can refer to the manual for instructions. It’s real easy.
I have a JV-300 but I imagine it would be similar on a JV-150.
William
