Peterbilt passenger door measurement
Andy D
I think it's a Peterbilt 389...
Does anyone happen to know
space on the passenger door between
the window and the rivets on the edge of the door?
Andy D
That's what I was thinking too, I have measured them on several different occasions,
but I'm not smart enough to record it anywhere.:(
I should be safe at making their logo 20" wide, wouldn't you think?
I would think so, but I'd hate to be the guy that steered you wrong. Hopefully I'm not far off, or someone else here has that magic number.
Mike Paul
Super Active Member
Looks to be apx. 20.25in. on this scaled pic of mine...
signage
you guys that said you have done a ton why not check one of the files for the size of what you place their.
strypguy
I did. At 18in you should have some space on both sides of the design unless you want to run it off the door edge and into the window.:)
equippaint
Same here, 18.5 was almost touching the rivets and an inch or less away from the window. I even double checked the picture i had of it before posting to make sure the door was the same.
