Photo mounting options
Colin
For fun I've printed off a few photos of mine (sample below is 19" x 27") onto matte vinyl and laid 'em down onto 3mm Sintra. The results are ok, but the 3mm Sintra seems a little thin, and now I'm thinking that it might be fun to make some more and try to sell them.
It seems like within the photography/art/print world there's either the "block-mounting" method, or traditional framing, neither of which appeals to me as I'd like to be able to do it myself (inexpensively) in-house.
The 6mm Sintra would be too expensive I think, so does anybody know of some other good material options to mount to? I somehow feel that foamcore/gatorboard doesn't quite cut it (too delicate?).
And while we're at it, is printing the photos on calendered matte vinyl a good choice over paper? It sure is nice having the adhesive on there ready to mount.
- Is a print on paper less susceptible to nicks & scratches than vinyl?
- Will I get a much better print quality on the Rite Media matte paper I just bought?
- Should I be covering them with something, or is the eco-sol ink ok as is?
Any other insight would be appreciated.
Thx
**This is a photo of a shot I took in Italy. B&W with a "Splash of Colour" effect.
unlaminated prints are ok, but somewhere along the way one of your customers are going to try and clean it. get some clearshield liquid laminate (water-based).
you can even add cool texture to your laminate with different rollers, could be fun to play with.
ex: gloss, dry, mask the leaves and give it a matte coating
Colin
Thanks Mike, I'll keep that in mind. Any ideas on the material options for mounting the print to? I guess I figured that we in the sign business might have some unique options up our sleeves.
Colin
Yes, that may be the way to go. However, it seems like a beveled edge is what people might expect, and I want to avoid doing that. A square-cut edge would need to be black as well.
Also, if a print on vinyl is as good as paper, I wonder if the adhesive will bond to the MDF surface.
Sticky Signs
You would have to paint the mdf first. One look I like is 1/4" sintra cut on a table saw with the blade on a 45º angle or more. Makes the print look like it's floating off the wall.
MikeD
art looks nice face-mounted on clear acrylic, and the acrylic can be fairly rigid depending on thickness. stand-offs glued out of sight on the back will float a picture on the wall with no frame. Images can be contour cut out of the mounted acrylic with a CO2 laser
jfiscus
Rap Master
I would be concerned about the longevity of the vinyl or adhesive that you are using. Most vinyls are only rated for 5-10 years, so what happens after that to the material; granted it's indoors, but the vinyl will eventually wear out compared to paper and will need replaced.
I would suggest the more traditional approach of printing to paper & using a mat to mount it & frame it, unless you are only marketing the contemporary look like in your picture.
MikeD
I am doing this with vinyl and an optically clear double sided laminate to clear acrylic...
What kind of paper do you guys use? The vinyl I have access too looks nice but lacks dimensional stability. I imaging that the paper is the best choice as long as it is protected on both sides.
What type of printing process (inks) are you using for the paper?
gnemmas
We print on gloss vinyl, laminate with matte film, then mount on 1/2" or 1" black "Ultraboard", which is foamcore with thin styrene on both sides that we make 3D letters.
Colin
^^^ Hey, great link signcrafters - thanks! They say on this page that they use "MightyCore", is that basically black foamcore? They also adhere white acid-free paper on the front; could one spray-mount a paper print to foamcore, or would that not last?
Colin
I'm wondering about the concerns that jfiscus mentioned above.
Added: I'd also like to avoid that "foam edge" look.
Doyle
I often print onto gloss calendered film, laminate with matte laminate, and make the print about 1" - 1.5" wider and taller than the panel, and wrap the edges of the vinyl over the sides and to the back of either 3mm or 6mm sintra. This gives a canvas-type wrapped look and customers really love it. I have tried adhering paper to various substrates with mixed results, but keep coming back to this method.
phototec
Gallery wraps
Coming from a photographic background and having worked the industry for a long time, I think prints like thode you are making would be considered wall art, and I find these types of prints sell better if printed on a canvas and mounted as a gallery wrap on stretcher bars.
Gallery wraps come in a few different sizes from 1" to 2-1/2" deep, I make all mine own stretcher bars and I make them 1-1/4" deep. On of my best sellers is a set of 5 prints in a cluster, a square in the center with 2 horizontal, and 2 vertical prints that surround the square.
Of course like any ink-jet print, you need to protect the surface of the prints, and I like to use a liquid satin product by Lexjet which can be either rolled-on with a foam roller or the preferred method of spraying with HVLP spray gun.
I just think display prints (wall art) look better on the textured canvas surface over the calendered vinyl, see example below.
Colin
^^^ Yes, I have a full roll of Neschen Monet canvas, but I'm looking for various mounting options for standard prints.
I just bought this Fletcher 2200 mat cutter yesterday (used) for $500.00 from a retiring artist; they normally go for about $2000.00. So this really opens up my framing options. It'll cut up to 48" mat. I've already filled a few 8x10 frames that were kicking around the house, and used my desktop Canon printer on photo paper. Sweet!
A proper 24" photo printer is looking mighty tempting. Please......someone stop me now! :Big Laugh
*image from internet.
phototec
Sorry, will NOT STOP you, because I love my Epson Pro 4800, it prints on 17" wide material. I just finished several 17" x 28" canvas prints, mounted on 13"x24" stretcher bars that are 1=1/4" deep.
Customer was extremely happy with them!
:thumb:
