Photoshop > Omega > Edge II ?
Discussion in 'Gerber' started by Signsforwhile, Feb 17, 2006.
  1. Signsforwhile
    Signsforwhile Very Active Member
    1,401
    Feb 17, 2006
    New York
    I am working on one of my first full color truck lettering jobs. I have designed a logo for a customer in photoshop and need to print it on my edgeII. I am unsure of what the best way to export it from pshop is to omega, because when I do it prints out extrememly grainy and looks horrible. The image needs to be about ~28" x ~11". At what resolution and what format should i export it and is there anything I need to do once i get it into omega?
    [​IMG]
    Thanks in advance! :thumb:
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,476
    369
    83
    Sep 11, 2003
    Olympia, WA
    The resolution (dpi) is irrelevant. Your image size should be created initially at about 1100 x 2800 pixels. That will provide enough pixels per inch (ppi) for the Omega RIP to give you an very nice print.
    Once you bring the image into Composer, select it and set the halftone type (in the Image Fill Dialog) to STC Photo and set the LPI to 70. A lage enough image and appropriate halftone/lpi settings will eliminate the graininess. If you are concerned about how it looks on screen, be aware that you are only looking at a thumbnail representation of the image which can be set to several different dsplay levels to save file sizes from getting too large. That image has nothing to do with the quality of what will actually print.
    I get the best looking results, color-wise, by saving out of Photoshop in RGB color mode with most any of the available RGB profiles and then output to the Edge using the Gerber Edge II CMYK 300 DPI output profile. You can use JPG, PNG, BMP format out of Photoshop with good results. I usually use JPG at a max quality setting of 12 and never resave it.
  3. Signsforwhile
    1,401
    Feb 17, 2006
    New York
    can i scale it once its in omega?
  4. Fred Weiss
    20,476
    369
    83
    Sep 11, 2003
    Olympia, WA
    Yes but I would get the cutpath created and aligned to the image at the size created first, then select both and group them before moving or resizing.
    What is the pixel dimensions of your original image file? Did you start from vectors? Do you have a vector cutpath?
  5. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    I'd make a light greyscale file of the highlight/shadow qualities of the beveled text... then print the job with spot silver & a lighter red. Then I would make the rastor image of the greyscale shading into a spotblack print set as an overprint & set my other vector black panels & outlines as overprint as well (to save foils) This way you get less "grainyness" but maintain the 3D loook.
    Maybe a llittle more complex then I make it sound, but worth experimenting with. For a building sign, process print grainyness is more tolerable... as seen from a distance... but on truck doors, they get seen up close quite often, especially by the owner... every day!
  6. Signsforwhile
    1,401
    Feb 17, 2006
    New York
    i was thinking of doing burgundy with shadow cast...
  7. Jeizzavelle
    Jeizzavelle Member
    91
    How do I export?
    I need to export a PDF file into Omega and it keeps saying it can't read it. I am trying to do ao logo and the only reasonable way I will bea able to do the thing is to import it into composer as a usable vector image cause it's Garfield and I have to do it in vinyl. It is the local phone co. and they have permission to use the image. No worries.
  8. Shovelhead
    Shovelhead Major Contributor
    10,882
    15
    Why a .PDF...........
    .TIF should be fine.
  9. Jeizzavelle
    Jeizzavelle Member
    91
    E-mail attatchment
    It is in PDF I am retarded. I need step by step. I am using Adobe Acrobat to view it. I have no clue.
    ETA: It was sent as an e-mail attatchment. It is going on a baseball sign (30x30) at the local ball field.
  10. Shovelhead
    10,882
    15
  11. Jeizzavelle
    Jeizzavelle Member
    91
    Ok, thanks alot.
  12. Jeizzavelle
    Jeizzavelle Member
    91
    Ok, got the e-mail but I tried to open it and it crashed composer. 3 times. BUT I REALLY appreciate your help.
    And here's a laugh for you. I am supposed to cut that out of vinyl and lay it on the sign. By hand. :tongue:
    :thankyou:
  13. Shovelhead
    10,882
    15
    As you know...........
    it aint happenin with that raster.
    :Welcome:
  14. Jeizzavelle
    Jeizzavelle Member
    91
    I'll get it. Boss is going to check on it for me. THANKS!!!
  15. Jeizzavelle
    Jeizzavelle Member
    91
    Shovelhead I just wanted to thank you again for trying to help me. I really appreciate it. And I feel like a dummy for wasting your time. But if I can get that file usable the image should be better than the bitmap image that I had. If I can actually see the image (instead of a bunch of blurry squares) it makes a lot of differance. (as you probably already know) Just, thank-you.
  16. Shovelhead
    10,882
    15
    The image that you sent me........
    is 2" x 3.25" @ 300dpi..............
    if you are printing at full scale that's more than adequate resolution for this application.
    Obviously, vectored artwork would be preferrable.
  17. Jeizzavelle
    Jeizzavelle Member
    91
    I am not printing it. I have to cut it out of vinly and lay it on the sign. We don't have a printer. I appreciate all your help. I got the image in there and have nearly perfect lines. A few minutes of adjustment and we'll be all set.
    The image is going on a white 30x30 blank in the local ball field. The fence is lined with similar signs from all the sponsors. We are (thanks to the VP) trying to get into more creative signs instead of just one way, road construction....blah. Thanks for all the help. You're a sweetie.
