Photoshop Question
Discussion in 'Adobe' started by schurms, Jan 1, 2007.
  1. schurms
    schurms Member
    461
    Do I want to create template backrounds in real size or create them smaller, say 10 times smaller and let it be resized at RIP ? what DPI should they be saved at ? Your help would be appreciated.
  2. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    for digital printing, I like the final file to be somewhere between 100 dpi & 300 dpi.
    On average size stuff (2' x 3') I might go with 150 dpi... unless it is a photo & is designed for up-close viewing... then I might go with 300dpi.
    For smaller 1' x 2' truck doors, I'd go with 300 dpi.
    For any large banner or sign (3' x 4' and up) I will usually settle for 100dpi, as the higher res files will only cost me time & hard drive space... but for distance viewing, it won't produce any real difference.
    As for a specific answer to your question, I would always design at actual size & design at least as high of a resolution as you want to send to your printer.
    In some cases if I am designing a logo with 3D effects & several layers & lots of my time... I may have a job to make a small sign today... but i may need a larger sign in the future, so I design larger then I need (and/or at a higher resolution) ...then for today's job, I will save a smaller version to speed up ripping their small print, & keep the larger file on hand if they want a big sign later.
  3. Ian Stewart-Koster
    Ian Stewart-Koster Active Member
    917
    21
    18
    Sep 27, 2003
    Qld, Australia
    What is actually on your template backgrounds?
    Is it a detailled picture, or a fuzzy gradient or something inconsequential, and where the dpi will actually make practically no difference?
    Are you talking about a vectorised file, or a bitmap file?
    What program are you working with?
