Photoshop - watermarks
Discussion in 'Adobe' started by WVB, Dec 1, 2005.
  1. WVB
    WVB Very Active Member
    2,749
    Is there a way to add your own watermark utilizing Photoshop CS2 without having to subscribe to Digimarc services? Thanks in advance.
  2. Derf
    Derf Very Active Member
    I would create a new layer on top then create Water Mark then change the opacity of the layer to desisted %
    I think that should do it for you.
  3. 3CGraphics
    3CGraphics Member
    381
    May 23, 2004
    ATL Area
    I make a mark in black on it's own layer and reduce the opacity until it's there but not intrusive - I usually put it below the 'real' layers though
    Steve
  4. Bobby H
    Bobby H Very Active Member
    2,006
    129
    63
    Feb 4, 2005
    Lawton, OK
    Sometimes I'll copy the technique used by a number of stock photo companies and have a repeating pattern of the company name going across the entire image. You can make the pattern very transparant, yet still noticeable. Some firms do a kind of embossed effect or glass like effect. The customer still sees the image just fine. But he can't repurpose it for his own uses at all.
