Pics of my shop
Discussion in 'CNC Routing & Laser Cutting' started by ernie, Jun 11, 2004.
  1. ernie
    ernie Member
    51
  2. geb
    geb Very Active Member
    1,847
    4
    38
    Apr 23, 2003
    Adirondacks
    Looks really nice, Ernie. You have some beautiful work and nice showrooms. Looks like you have alot to offer in the sign trade from vinyl to routed signs, and much more. Nice setup.
    George
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,919
    544
    113
    Sep 11, 2003
    Olympia, WA
    Looks great Ernie.
    Not sure what the problem is, but every time I navigate using your links I get a 404 Page Error. Clicking the back button in my browser then lets the correct page display.
  4. Dennis Raap
    Dennis Raap Active Member
    586
    Oct 5, 2003
    USA
    Ernie looks like a nice setup you have if I ever get some free time I will post some photos of our place. :cool1:
  5. Jen Goodwin
    Jen Goodwin Active Member
    868
    Dec 17, 2003
    Maine
    I especially liked the pics of the router being put together and in the crate!! Very cool :thumb:
    Thanks for sharing.
  6. ernie
    ernie Member
    51
    Fred,
    Thanks, I didn't notice the problem.
    The site is hosted by Cadlink. It's a 1yr free bonus for buying signlab7. Although it is very easy to setup and upload pictures, the system stability and site uptime has been less than outstanding.
    I'll let them know about this issue.
    ernie
  7. ernie
    ernie Member
    51
    Thanks for all the nice comments, I really need to keep the shop cleaner, but I hate to throw stuff out.
    The crate is still useful, we stood it up on end and put shelves in it. Now it stores my tool box and power tools.
    ernie
  8. exsigns
    exsigns Guest
    hello ernie,
    can you tell us more about building vacuum hold down system?
    Thanks,
    Stan
  9. ernie
    ernie Member
    51
    I constructed the vacuum table like an air hocky table, except I used 2 4x8 sheets of 3/4" MDF. I used the router to drill a hole every 6" in the table. These holes were plugged with automatic "ball valves" so there are no air leaks to reduce the vacuum. A grid pattern of adhesive weather stripping is used to isolate each "ball valve".
    I can place a sign blank anywhere on the table and it is held in place automatically.
    The best feature is that the design is so effecient that I use a Fein shopvac instead of a 5-10 hp blower.
    ernie
  10. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    What about if you need to cut thru a part entirely?
  11. exsigns
    exsigns Guest
    hello Ernie, I hope I will not ask for too much... i'm looking to get one of this systems for my self from practicalcnc.... can you please post more detailed pictures on a vacuum hold down sysytem and pictures of it's main parts... valves... connection...etc. Also if you would a step-by-step instructions on how to do it.
    Thanks,
    stan
  12. Dennis Raap
    586
    Oct 5, 2003
    USA
    Chris, when I need to cut through I use transfer tape on the bottom side this also helps to hold small parts in place. For lagre pieces I will use a piece of sacrifical material under the piece that I want to cut.
  13. ernie
    ernie Member
    51
    Chris,
    I use peg board as a layer under parts I cut all the way thru. The advantages of this approach are many:
    1) it's cheap. 2) the holes transfer vacuum straight up to the part and minimize leakage to the sides. 3) the rough side really grabs the signfoam. 4) it can be cut to the general size of the sign to eliminate activation of unneeded ball valves. 5) it can be used many times before it's worn out.
    Stan,
    I was thinking of writing an article on how to build a vacuum table but decided there was not much interest by sign makers.
    ernie
