Question Platen Gap- Epson surecolor 40600
coastguy111
I had to set my adhesive vinyl (6mill) to 2.0. I was told by all techs 1.6 was fine for all adhesive vinyl but it was causing head strikes, bad color etc.
Sent from my SM-N960U using Tapatalk
SignMeUpGraphics
Super Active Member
That's fine then.. if your media is buckling you can either reduce the heater temperatures, or increase head height. I prefer to lower the temps a little as the GS3 inks seem to perform nearly equally as good without the heaters even being turned on.
