please help I need to make a decal for the left side an right side of a boat
BryWY
but I dont know how to make one for both sides that point the same direction can some one please help urget
GAC05
Quit buggin' me
What software are you using to do your layout?
Depending on what it is look for something like 'mirror' or 'reflect' to take one side and make it work on the other.
If you are using Power Point or MS Word I don't think we can help you.
BryWY
GAC05
Quit buggin' me
art cut when i use mirror it shows backwards
What does the graphic look like? Is there text in there - i.e. name of the boat?
Graphics have to be mirrored to end up pointing in the same direction on 2 sides of a boat.
Do a screen grab and lets see
letterman7
Your general description of "decal" doesn't tell us much. Artcut is a very basic, cheap program which is limited in what it can do. You should be able to mirror graphics with no issue, but mirroring text probably wouldn't work. You'll need to create the image on your own.
BryWY
GAC05
Quit buggin' me
Is that a contour cut around printed (or cut) lettering?
If it is lettering then they can't both point to the front of the boat.
BryWY
GAC05
Quit buggin' me
OK,
so if it is letting with a contour cut you will have to redraw one side to get the shapes similar on both sides.
Text, at least in the US, is read from left to right so just mirroring the design will not work.
Do you have any more of the design you can share?
Texas_Signmaker
Very Active Signmaker
just create a different logo that doesn't need to point in a direction... problem solved...I'm leaving to get peas soup too
