Please Help Identify This Wall Mounted Banner Bracket
appropriate1
The picture is a wall mounted cast aluminum banner bracket with a broken pole. I think it might be easier to try replacing the entire bracket than to remove the remainder of the pole and hope the other I have fits. If I can fns the same brand, the hols in the wall should match for replacement. Most wall brackets I see in my current catalogs have four hole on a flat plate, but this one has just two. Any advice appreciated. It is very high, but I can reach it out the window enough to bolt on a new one, but maybe not drill new holes for a different brand bracket. Thanks, Rob
