Please tell me about the HP 335 and 365
Andy D
The Business owner want to replace our eco Solvent Roland with latex and wants me to find out more about the HP 335 and 365. From the people that run them, are you happy with them?
On the 365, is the spectrometer any good? It doesn't replace an eye-one does it?
We will likely get the summa plotter with it, the have a barcode reader built it, is that any good?
Thanks for any info.
balstestrat
Problem Solver
So the differences between 335 and 365
  • Spectro which is nice addition but it can't do everything that external one does. Like transparents, backlit, fabric, non-white material etc. What it can do is basic profiles very very easily.
  • 365 is a tiny bit faster, just has an additional heater.
  • 365 has a better spindles for material rolls.
  • 365 can do fabrics and stuff that let's ink through with the ink collector.
  • 365 has a bigger screen but it doesn't really make big difference in daily use.
  • 335 probably comes with Flexi RIP but 365 doesn't so add the RIP to the Cost as well.
I would buy 365 if the price difference isn't too much. You should be able to snatch one at ~$15000.
And the Summas a work horse. Just stay away from MX graphics and thiccc stuff I guess (from the other threads). There's new models coming soon so think about that.
Andrea_neon
We have an 335 and love how easy it is to use. Everything you need to do, change, etc, shows in the screen and has step by step tutorials of how to do everything. We print a lot of vynil, we don't usually print fabrics so 335 works great for us. Flexi RIP works well but I've never tried another RIP so don't have anything to compare with.
mpn
We went with the 335. It was our first Latex as we have Roland and Epson too. The 335 is great. The things that will take getting used to is the lag time on short run stuff compared to the Roland. It takes time to heat up, cancel jobs etc. Not really downsides but it is slower doing things like that. Long runs are great and it tracks straighter than any printer we have. Take up system is top notch compared to the others. It self cleans, has a maintenance cartridge and head replacements are a breeze, which we like. We use mostly generic profiles and some vinyl manufacturer canned profiles. Color is nice and reds come out okay. We've run ours for close to 3.5 years now. If you have any 335 specific questions let me know.
Pauly
Printrade.com.au
wouldn't rely on the onboard spectro. would rather have a separate one. onboard one would be limited what you can do with it.
Chriswagner92
We went with the 335 since April of 2018 coming from an sp540v, and the difference in production speed was astronomical. The thing is so easy to maintain, not that it needs much. I think the heads we have in there now are like a year old and still firing perfectly. My only gripe is how much waste it produces compared to the 540. It needs about a foot leading otherwise it catches on the heater and crashes, whereas the 540 was pretty much right where you want it. Definitely get the takeup option if it doesn't come standard.
Andy D
I had used a different model HP Latex & it was the same way until I changed the heat settings & found the sweet spot of the lowest temp that cured the ink.
On that other HP, I couldn't pause a print without losing what I had already printed... is the 335 the same? Also, I couldn't print vinyl unless it was on a roll, same?
balstestrat
Problem Solver
The heat settings doesn't have much to do with the need for extra margin at the front because it happens before the curing. It's the material that makes the difference. Some crash easily and some you can print from zero lead.
Only way to "pause" is to open the window and then it will pause and continue after but you risk having a defect and there's like a 5min time limit.
You can print sheets but there is limitations to that. You need an extra 3-feet at the end so the ink cures properly.
Commando
We have a 360 and 365.
I hate them both. And HP/Grimco tech support is virtually non existent. They(HP) charge 50 bucks just to speak to someone!
The color isnt consistent. It prints short lengthwise. One of them leaks optimizer and HP came by, scratched their heads and left.
Also, if you change out vinyl a lot, you are going to get a lot of waste.
Look into Epson, is my advice.
balstestrat
Problem Solver
Is it leaking from the carriage? There's a pretty easy and "cheap" fix for that...
Most likely need to just replace the FI tower.
tudouqiezi
Sounds good, any news that Summa will update the S2 series?:rolleyes:
I'm thinking of replacing my FC8600 with an FC9000 and if SUMMA updates the S2 I can think about it.
signheremd
We have a Graphtec FC9000-160 and love it - just a typical Graphtec workhorse. Price was so much better than the Summa too - though Summa makes a really nice unit, so you can't much go wrong with either choice.
Commando
The tech said he couldnt figure out where it was coming from. There is optimizer all over. Up top, on the bottom. Rollers. Lol its a big mess.
balstestrat
Problem Solver
I bet it's the FI tower then. It's just a tube from there to the cartridge so there's not a lot of possibilities.
