Plotter acting weird!
Jillbeans
This rats-n-fratzen 4E must have become satanically posessed over the weekend.
I have a job which is to be installed tomorrow.
When I go to cut, the plotter acts OK for a few seconds, then I can hear a slight hitch in the belt and a different tone in the normal sound of it.
Then the cutter part goes off the cut line altogether.
For example, it will cut the first top radius of an oval, make that sound, then go to the left in a straight line, then back upon that cut, then start cutting the bottom radius of the oval.
The theta belt is not old.
The cat has now been locked in the bathroom, she grabbed the punched edge of the backer paper when the damn plotter was actually cutting OK for a few seconds, and almost had her paw go through the pinch roller.
I just don't want to waste any more material than I already have so far today! Any ideas?
(besides buying a new plotter)
:thankyou:
Love....Jill
mamos
Is it just doing it with this design or is it doing it with any cut file.
Did the cat actually stop the media from going into the machine
Do you want a hug
mamos
Marlene
did you make sure that the object that you are cutting isn't bigger than it should be? I haven't run a one of those old guys for many moons, but my plotter does that if I try to cut some thing that is just over the max height limit.
Jillbeans
It did do it with the first two files I sent. One was at 13.25" which is pretty big, so I turned off the weed outline thing. But it still did that weird thing.
Believe it or not I think the damn cat solved my problem!!!
I think it was because I am using a brand-new roll of media, which may have been too tightly rolled on its core. When it yanked the cat back I think it loosened itself. I've rolled off a bit of extra at the feeder end.
Love....Jill
PS Mamos, I would take a hug from you any day!
mamos
I wonder if you could train a cat to do the weeding?
Their claws would be pur-fect
mamos
Jillbeans
Like this?
Damn cat would rather lay around or generally get in the way.
mamos
We have a new helper in the workshop as well
Please welcome Woody
mamos
Marlene
you both have some very cute little helpers. I leave my three at home but they help (?) out around the house.
Jillbeans
Woody looke like more fun than Dottie!
Here's our Sukey. At least she doesn't mess with my plotter.
She does love to chew those little end cap things which come on Oracal rolls!
