Plotter Blades
Discussion in 'General Signmaking Topics' started by showcase 66, Sep 30, 2010.
  1. showcase 66
    showcase 66 Very Active Member
    1,833
    4
    I just ordered some new blades and the lady I was just telling me that I need to change my blade out every month. I have never heard that before and am taking it like she wants me to purchase more from them. But it got me thinking how often do I change my blades. I have 4 cutters set up and they pretty much have their own type of work to be done with. 1 for sandblast material, 1 for small decals and the other 2 for pretty much everything else. I have changed blades pretty quickly when I am using reflective or other specialty films that seem to kill the blade.
    Anyways. Just curious how often everyone changes their blades.
  2. MikePro
    MikePro Major Contributor
    4,974
    235
    63
    Feb 3, 2010
    Racine, WI
    depends on the quality of the blade you're purchasing... i don't know too much about plotter blades, as someone else in the shop does most of the cutting, but a good comparison would be drill bits. The gold colored bits last at least 4x longer than the black oxide ones that cost half the price.
    i CAN mention that, i change my plotter blades about twice a year... and we cut about 4hours out of every day, 5 days a week, same blade for all materials, just different depths/pressures.
    (although we don't use sandblasting material anymore, as we route everything now... but we do put the blade through the ringer with reflective and laminated materials quite regularly.)
  3. tomence
    tomence Very Active Member
    1,647
    25
    48
    Feb 10, 2009
    IL
    I change blades once or twice a year and i cut a lot of vinyl, and i change blade not because they are worn just because i want to and i believe that i can use the same blade with the same amount of cutting vinyl for over a year.
  4. CES020
    CES020 Very Active Member
    2,875
    4
    38
    Oct 16, 2008
    VA
    Do yourself a favor and buy cleancut blades and you'll never buy another blade from that woman again.
    Best blades I have ever used. I bought several and they are still unopened because the first one I put in is still cutting like a dream. Amazing blades.
  5. BadAss
    BadAss Active Member
    577
    Nov 29, 2007
    Arizona
    We cut about 3-5 hours a day. My Summa blade lasted 3 years, replaced with Clean-Cut blade about 6 months ago and it is still going strong. Both of our Summa blades lasted more than 3 years...
  6. Moto
    Moto New Member
    11
    Summa blades work good for me
  7. weaselboogie
    weaselboogie Very Active Member
    3,835
    9
    38
    Apr 23, 2006
    Us
    :thumb:
  8. Dave Drane
    Dave Drane Very Active Member
    2,540
    1
    +1 . f you did a search you would have known this long ago. Ross is the man and I believe he does a discount for members. CLEANCUT BLADES, only way to fly!!:thumb:
  9. BobM
    BobM Very Active Member
    2,146
    44
    48
    May 31, 2008
    Cape Cod
    Clean Cut blades are the best and their service is great. 866-579-0963.
  10. TresL
    TresL Very Active Member
    1,010
    Oct 24, 2005
    Clean cut here as well....
    I go though A LOT of blades doing 22+mil mateial.
    Only issue with Clean Cut.... no Summa T blades... :-(
    GREAT guy to talk with, he went as far as to recomend a place to get the T blades...
  11. Bill Modzel
    Bill Modzel Active Member
    I just switched to Clean Cut myself. I cut tons of .oo5" lexan with a heavy duty adhesive laminated to to the back, with my GsX Plus. I generally have 4 cut paths stacked. I dropped the paths to three and dropped my knife pressure in half and am still tweaking things.
    I've also dropped the pressure on my Graphtec 1/3 to 1/2 what I was using on vinyl and rubylith.
  12. klemgraphics
    klemgraphics Active Member
    624
    Jan 13, 2008
    Midwest
    I must be hard on my blades or something, I use clean cut also on my FC7000 and I change them about once every 2-3 months.
  13. omgsideburns
    omgsideburns Very Active Member
    2,180
    Apr 15, 2008
    We have two blades on each of our plotters.. one for regular vinyl, and one for reflective. We get at least two years with daily use.
  14. steve.leleaux
    steve.leleaux Member
    27
    Mar 11, 2011
    Chattanooga
    where was the recommended place and did it work out for you?
  15. TresL
    1,010
    Oct 24, 2005
    Ordered them through Fellers, they seem to be OK.
    Next order will be from Phil at the Summa Store though.
