Plotter Pressure
Jackpine
Select condition and more the right arrow key to pressure and adjust up or down. Hit enter and then hit "test". Weed the vinyl and if it weeds easy and does not make an impression on the liner you have a good pressure. The Graphtec has different conditions you should pre set for speed and force for different thicknesses of material. Or there is a manual on the CD or contact your supplier to help you set up. It is pretty easy once you go through the steps.
How do you adjust the pressure on the plotter pin? Graphtec 5000, thanks for the help!!
