Plotter settings for an old roland
Kottwitz-Graphics
I am working tring to get an old PNC-1800 going, and I am not sure of the settings that I should be using.
Plotter is a PNC-1800, and I am cutting from Corel X3. I have it plugged into the front USB port on the computer, and it shows "Roland CAMM-1 PNC-1800 / Ready" in the printer setup (start/settings/printers)
One step further, when I click on properties, and open the tabs, under ports, it reads USB - Virtual port to PNC-1800. Device settings tab - Polygon Fill is off, toolwidth is default to .30 mm
Under the color management tab color management is set to auto.
On the front panel of the 1800, it reads "Coordinate Display x = 0mm y=0mm"
Do these look right to you guys? When I send it to print, it sends it to printer que, and just sits there.
Thanks in advance.
Cadmn
check the line thicknesses sounds like you don't have them on Hairline, so the cutter is confused My thoughts any way
