Plotting 3M 3930 Series High Intensity Prismatic Reflective
CG
Hi, does anyone have experience cutting 3M 3930 Series High Intensity Prismatic Reflective on the Mimaki CG 160 FX? I have tried 45 and 56 degree blades with a pressure setting of 400, at various blade depths, speed is at 5%. Just cutting 5 x 24 rectangles...some have radius corners. Thanks!
nuke
signs since 1999
here is my 2 cents
SPB 0006 blade, 306 pressure, 4.33 what we use don't change anything but the blade length out of the holder about 3 times the normal length exposed,
Just cut 50,000 digits
Good luck hope this helps
CG
Thanks for the reply! I will order those blades. What is the 4.33? Is 4 speed and .33 the offset?
CG
THANKS!
Thanks for the help on this! I am underway cutting Prismatic. Here are the settings that worked for me.
3M 3930 High Intensity Prismatic:
BLADE: SPB-0006
SPEED: 5
PRESSURE: 370
OFFSET: .75
PROTRUSION: .5mm
**I had to cut on the back...the white side. Worked great!
3M 3336 High Intensity Flexible Prismatic:
BLADE: SPB-0006
SPEED: 5
PRESSURE: 170
OFFSET: .75
PROTRUSION: .5mm
