pms 343 cmyk value..is this website ok?
Discussion in 'General Signmaking Topics' started by rushworks graphics, Aug 9, 2011.
  1. rushworks graphics
    rushworks graphics Very Active Member
    1,423
    i have yet to get a pantone book that gives the cmyk value.....i know, i know, its one of those things every sign shop should have but i have yet to get my butt in gear on this!
    i need to print pms 343 (green) and looked online for its cmyk value so i can then go into illistrator and type it in the color chart and i came across this site. anyone with a pms chart know if these values are accurate?
    thanks guys!
    http://www.zedimage.com/pms-cmyk-hex.php
  2. wildside
    wildside Very Active Member
    1,466
    18
    38
    Aug 28, 2005
    Kansas
    my chart says PMS 343 is
    c 95
    m 15
    y 62
    k 58
    or
    r 3
    g 86
    b 66
  3. rushworks graphics
    1,423
    thanks guys........so that online sites chart is incorrect then?
  4. ucmj22
    ucmj22 Very Active Member
    1,509
    1
    Roland Spot color DP-15G looks almost dead on in sunlight
  5. rushworks graphics
    1,423
    ah, ok, thanks man, just have a quick look on one of my roland wall charts, good to see it as a reference.
  6. WrapperX
    WrapperX Active Member
    754
    The real kicker is that even though your Illustrator sliders are going to show you the right "pms" break down - your printing/rip software won't interprute it that way and there fore won't print those perfect break downs. Good luck with that!
  7. rushworks graphics
    1,423
    anyways around that?
  8. ucmj22
    1,509
    1
    yes, use the spot color.
  9. WrapperX
    754
    Not that I know of. Normally what we have always done is print a solid to process color chart for every profile on that particular material and then using a Pantone booklet swatch match it to what looks best on the sample profile chart. It's a complete PITA but it hasn't failed us yet.
  10. WrapperX
    754
    I've had trouble with spot colors...so maybe you know something I don't.
  11. rushworks graphics
    1,423
    so best bet then is to go by the roland color chart as ucmj22 suggestes then.....
  12. WrapperX
    754
    .... :covereyes: .... might be the best way. Bummer I know, but....
  13. ucmj22
    1,509
    1
    1: is your design Vector?
    2: Make sure you convert spot color in Versa
  14. rushworks graphics
    1,423
    yes its a vector, and yes i always have the spot color checked in vw..........thanks for the input, appreciate it.
  15. ucmj22
    1,509
    1
    then that spot color should do the trick
