pnc 1000a solenoid needed
Discussion in 'Roland' started by Simon-vane, Jun 3, 2012.
  1. Simon-vane
    Simon-vane New Member
    5
    Hi everyone, Bought a second hand pnc 1000a plotter off ebay apparently in excellent working order (NOT) first thing I discovered when I turned it on it smelt like something dead was inside it so anyway went to set the blade to do a test cut and noticed the head wouldnt move up and down, took it apart and found the solenoid was was stuffed. told this to the guy I got it from and all he said was I should of had a professional to look at it before I bought it, well if he had of put in his description of sale, plotter not working solenoid burnt out and has something dead inside it I would not of given it a second look.
    anyway stuck with it now and just like to ask does anyone out there know where I can get another solenoid for the cutting head..cheers
  2. OldPaint
    OldPaint Major Contributor
    that is such an old machine, the 2nd series of the 1st ROLAND. PNC-1000 was 1st one. that particular solenoid i would bet is the same from the PNC-1000 up to the GX-24. call roland and see if they think the same. i had a PNC-1000, 2- PNC-1100's & now have a CX-300, and to me that part looks the same on all. if you paid more the a couple hundred for it you got ripped.
  3. Simon-vane
    5
    Thanks for the feedback Oldpaint! yes I definately got ripped. well what you have told me opens more doors for investigation, cheers
  4. visual800
    visual800 Very Active Member
    3,632
    178
    63
    Aug 4, 2010
    montgomery, alabama
    simon i dont know how long ago you bought it but ebay loves its buyers. Demand a refund and leave negative feedback IF the seller does not make right. like I said depending on when you bought it.
    in the meantime I have seen these machines for parts all over the web
  5. Ian Stewart-Koster
    Ian Stewart-Koster Active Member
    813
    7
    18
    Sep 27, 2003
    Qld, Australia
    I don't think Roland changed much in the plotter-blade holder & solenoid department over 10+ years.
    If you get nowhere with the seller, you could possibly consider winding a new solenoid yourself, if you're that way inclined? I'm sure it's not much more than a glorified coil of wire around a sewing thread spool, attached to a spring! You'd just need to count the number of turns, and the gauge of the wire!
    What did you pay actually?
  6. signage
    signage Major Contributor
    9,207
    25
    48
    Oct 5, 2005
    Penn
    :goodpost: And don't forget the length of wire.
  7. Simon-vane
    5
    only got it last monday and paid for it about 3 weeks ago.
    I have left very negative feedback and asked for my money back but he refuses to give it back..still trying as I think he should do the right thing..
  8. visual800
    3,632
    178
    63
    Aug 4, 2010
    montgomery, alabama
    BS! you file a complaint with ebay and they will get your money back and make him take item back. you do not ask the seller tell ebay and they tell paypal. paypal will lock down his account! do it TODAY!!!
  9. S'N'S
    S'N'S Active Member
    963
    25
    28
    Jun 5, 2008
    Australia
    Do what Visual800 said, you claim your money back thru ebay NOT the guy that sold it to you.
