Pole Banner Finishing
Discussion in 'General Chit-Chat' started by Greg Kelm, Sep 1, 2020.
  1. Greg Kelm
    Greg Kelm Member
    94
    12
    8
    Aug 20, 2019
    Rancho Cucamonga
    Anybody heat welding pockets for their pole banners? I'm using 18oz blockout banner for a job and wondering if a heat weld will be as good as a stitch. Please advise.
  2. WYLDGFI
    WYLDGFI Merchant Member
    1,195
    102
    63
    Oct 27, 2006
    Linden, NJ
    Been doing this a long time....I still stitch. We havent/don't lose any with wind or storms that way. Always nice to have a client call us and say they had zero issues during a storm with our banners for their clients!
    • Like Like x 1
  3. Billct2
    Billct2 Major Contributor
    7,461
    640
    113
    Mar 12, 2005
    New England
    I have used Wyld for stitched pole pocket and street banners and they always held up.
    • Like Like x 2
  4. GAC05
    GAC05 Major Contributor
    5,931
    790
    113
    Dec 27, 2005
    Guam USA
    We use HH66 to lay everything out and add a stitch on the pole pocket seams.
  5. WYLDGFI
    1,195
    102
    63
    Oct 27, 2006
    Linden, NJ
    HH66 is a bit sloppy unless you have a great method to keep the glue where its supposed to be. We will usually DF tape before sewing. Our boulevard banners if we do them "bulletproof" get heat sealed hems and then doubled over. Street banners are similar but true 4/4 printing on those with the webbing sewn in.
    • Like Like x 1
  6. GAC05
    5,931
    790
    113
    Dec 27, 2005
    Guam USA
    With some practice and a sharp edged putty knife (think setting bondo or drywall putty) you can lay down a smooth even layer of 66 were you want it. We use a wood glue dripless squeeze bottle to drop the glue for spreading. Have not had much luck with tape in this heat and wind but it could be crappy tape. On the other hand the glue joint seems to get stronger the longer it is out in the weather.
  7. WYLDGFI
    1,195
    102
    63
    Oct 27, 2006
    Linden, NJ
    Got it...sounds like you have that worked out well. The tape helps keep things aligned before and during sewing. Had too many issues where a banner comes out of the sewing machine cockeyed and not straight.
  8. Greg Kelm
    Greg Kelm Member
    94
    12
    8
    Aug 20, 2019
    Rancho Cucamonga
    Thanks for the input, much appreciated
