Poles for Cabinet Sign
LJ4133
I'm looking for steel or aluminum poles to ground mount a 10' x 10' cabinet sign in Atlanta. Where can I buy the poles? They can be square or round 14' in length.
skyhigh
open yellow pages... go to the header "STEEL"
First, contact an Engineer...give him the specs to your project, and he will tell you what you need.
onesource
A couple of 5 or 6 inchers will work and from your description there will be 4' of the poles in the ground and the rest running up the sides of the cabinet.
24" holes 4' deep should be fine for a 10x10 on grade level. Here in Birmingham an engineered drawing is not required on anything under 20', the city engineer reviews the drawing and foundation work and will make changes accordingly. Some cities require one on everything.
Steel companies sell in 20-40' lengths but will cut them for you.
Good luck on your project.
