Polling problem with Flexi 7.6v1
Discussion in 'Flexi' started by stopngo, Jul 21, 2005.
  1. stopngo
    stopngo Member
    136
    Hi All. My problem is that when polling my FC5100-130 (54" Graphtec) plotter, the numbers come back for the width 1 decimal place off. Example, the cutter will say that the media is 22.3 in wide but when polling the software says 2.230 in wide. Any idea why this is?
    Thanks,
    Corey
    <!-- / message -->
  2. Fred Weiss
    Fred Weiss Merchant Member
    20,919
    544
    113
    Sep 11, 2003
    Olympia, WA
    Sounds like a software bug to me. Have you reported it to Scanvec-Amiable?
  3. Kustom DeZigns
    Kustom DeZigns Member
    122
    Scanvel-Amiable is not NICE to me....
    They will not help with my own Flexi problem :(
  4. Fred Weiss
    20,919
    544
    113
    Sep 11, 2003
    Olympia, WA
    Okay then has this machine worked with previous versions of Flexi without having this problem? Has it worked okay with any other software? What changes have you made to your setup, including your computer, plotter and any software you installed or changed anything about in the week or so preceding the first time you noticed the problem?
  5. jayhawksigns
    jayhawksigns Very Active Member
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    I notice the same thing occassionally, but I haven't upgrade to anything 7.6 yet, still using 7.5v5. Any my main plotter is a Summa.
  6. stopngo
    stopngo Member
    136
    Yes, I just installed 7.6v1 this week and had 7.5v5 on previously. Didn't have any problems with the earlier version.
  7. Fred Weiss
    20,919
    544
    113
    Sep 11, 2003
    Olympia, WA
    You might want to check with your distributor then about geting a copy of 7.6v2. I got mine about two weeks ago.
  8. stopngo
    stopngo Member
    136
    Downloaded and installed the upgrade for 7.6v2 and still no good. Received and email from eSupport @ Flexi and this is a direct quote:
    "Corey,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p> </o:p>
    You are correct that is a bug in the software. It is a known issue and at this point there isn’t a fix."
    So There you have it.<o:p></o:p>
  9. sign-solutions
    sign-solutions New Member
    7
    Definitely a bug. Just upgraded to 7.6 and now see the same polling issues:
    1) When using "Roll1" on Graphtec, Polling twice causes decimal place to be off by factor of 10.
    2) When using "Sheet" on Graphtec, it measures correctly!
    Sign & Graphic Solutions, Inc.
