Position Invalid Out of Range - VP-300
readmore
Hi there!
We have a VP-300 main board go bad, so we replaced it and I am trying to run the reinitialize limits. I lock the carriage (making sure it's locked), start the process, slide the cutter all the way left, hit "enter", the cutter moves right, gets to the end, does it's wiggle but then I get
"Position Invalid Out of Range"
Does anyone have any ideas? I'm new here and not 100% on the lingo so be gentle.
a note: we have a vp-300 but when I boot up it says VP-540 on the LCD, not sure if that matters.
Thanks a bunch!!
GTSTech_1
Sounds like you bought a used main board that came out of a 540 model. I would suggest re-initalizing the mainbaord......I think its hold down the up and down button while turning on the sub-power., then perform the encoder setup and calibration after you have setup the limit.
My .02
