Pounce / Vinyl Cut plotters - Recommendation?
Discussion in 'Miscellaneous Plotters' started by Kest, Oct 26, 2020.
  1. Kest
    Kest New Member
    1
    Oct 21, 2020
    Midwest
    Looking for a 48" inch plotter mainly for vinyl lettering/stencils, and also creating pounce patterns.
    I've gathered a few options through forum searches and online sources, and have seen positive reviews for the following:
    Summa S120
    https://www.hhsignsupply.com/productcart/pc/Summa-S2-T120-48-inch-Tangential-Vinyl-Cutter-p46597.htm
    Graphtec FC 8600 (with pouncing attachment)
    https://www.uscutter.com/Graphtec-F...jAFr7fI36_wj-F-2ykpzIIvE3KJly2fkaAtCXEALw_wcB
    Allen Datagraph
    https://allendatagraph.com/traffic-and-signs/itech-traffic
    Any advice or recommendations on these or others?
  2. Gino
    Gino Premium Subscriber
    33,493
    2,387
    113
    Jun 7, 2006
    PA
    We have a 30" Gerber. It can pounce and pounce and pounce and never skew, no matter how much back & forth movement you have. Longest we created was about 10' × 80' That was done in 3 passes and taped it together.
    Don't know the range of any of those others.
  3. WYLDGFI
    WYLDGFI Merchant Member
    1,290
    145
    63
    Oct 27, 2006
    Linden, NJ
    Graphtec 8k is solid.
  4. Jean Shimp
    Jean Shimp Member
    247
    29
    28
    Oct 26, 2012
    jacksonville, fl
    I use a 30" Graphtec for patterns. I can't trust it for anything longer than 6' at a time because it goes off track. Partially it is the fault of the roll of paper, since it often has creases that throws things off. I'm not crazy about the constant pounding of the pounce pin on the machine or the type holes it makes but I can make it work. By far my old sprocket fed Gerber 4B was a champ at making patterns. But it died.
