Thing is, with Switch, you can create check points inside the workflow. So you can basically have full automation by default but then ask for an operator to do a quick visual check.even then, i think there will still need a human approval as ai will not aways get it right
Option A: file is ok, operator can release the file to the flow.
Option B: file requires manual corrections, then you can edit/replace the file and release it to the flow.
That's basically maximizing the automation while keeping operator control when it matters.
Loic
