Flame
Thanks for the help Kevin. I will look around.
Don't forget though, the Edge 2 costs more than the VersaCamm.
But it's a strong machine.
What machine do you like best Flame?
I meant which of the ones you own. I know verry little about large format. The edge is a workhorse but has it's limits
The edge will cost more to use probably. Especially with 4 color process,plus it isn't convienent to load 4 seperate foils
When you add in the cost of laminating film and the labor to apply it to inkjet output, the Edge comes out the winner costwise. As to convenience, waiting for drying and then having to laminate much of the output, is also highly inconvenient. Then there is the question of noxious fumes. Being able to print white and dozens of spot colors and do bleed cuts without concern that the solvent ink may have reacted with the adhesive and that the edges of the vinyl will start curling up.
Shall I go on?
Your not really looking for smaller Just Cheaper right?I already looked at the VersaCamm 30" and I really like that (that may be an option also), But if there is something smaller that you all may know of I would be interested in looking at that.
