print & cut outline issues
wabam
I have a line of text with 2 layers already outlined. I need to cut only around the outside of BOTH layers. How can I outline the whole object so, it doesn't cut the drop shadow as a seperate piece?
Thanks for your help on such a newbe question.
Bill Modzel
Select the outer line and go to object>path>offset path. If you end up with overlapping shapes, unite them with effect>pathfinder>merge. Be sure to "expand" your effect.
Jim Doggett
It depends on which program you use. Newer versions of CorelDRAW have a contour feature that'll outline groups of objects. However, I've always found it quicker to make a copy in place (+) and weld it (click weld icon).
Best,
Jim
