Hello again
I have replaced print head (left one) few months ago. At that time i was using colors that was not original. Already then there were some problems with black nozzles. they werent ok. The tech said that it is probably becouse of non-original colors, and that eventualy the head should be ok, when i will print some material... Now im using original colors again, and the black still has some missing nozzles, but sometimes it was ok. Now i cant get clean nozzle check! So, i did complaint about print head, becouse it has 3 month warianty, but tech-guy said, that he can't do complain becouse i used other colors. So, do you guys, wich are using other colors know that warianty has no meaning if you use other colors???
