Print head question
printcleric
Is there any reason I shouldn't use a solvent print head with water based ink (dye sub)? Also, are the RJ900x print heads compatible with VJ 1304W printers? Thanks in advance!
All Mutoh print heads are now solvent resistant including the RJ900X. All print head prices have also gone up. This started at the end of last year some time. So what I am saying is, you're good to go as long as you aren't trying to put dye sub through a used solvent head. That will cause problems. New heads are fresh and ready for whatever ink you put through them.
