Print is unsticking...
msenjur
Hello!
We often mount our prints on forex. And very often the edges unstick over time. is this vinyl problem? too much ink?
How do you monunt prints on forex? with lamination?
gbarker
Assuming you are doing a full bleed - That's most likely your problem. Haven't tried it myself but you might be able to use 3M primer...
The easiest and fastest solution is to leave a 1/4" white outline around the print. Most vinyl suppliers recommend doing this.
