Hello, I've had a big problem with my BN-20 printer for a few days now, first it all started because I wanted to change the print head damper (because the yellow wasn't coming out anymore), during the 1st reassembly I had a bit of liquid in the print head cable plugs, and when I restarted I had a problem with the print head leaking (all the inks were coming out at the same time), Then, after asking a professional for advice, I replaced the 4 print head cables with new ones and cleaned the head (and dried it completely). After changing the cables, I was able to run a few nozzle tests, then after about 10 tests, I ran a versawork print test and the problem came back. ... do you know what to do? Thanks a lot
