I'm using mimaki uv printer (sij-320) and print out the result size which is fewer than the size that I want to print, especially I print long feed size of tarpolin.for example, I want print out 193" feed size but I print out the size is 192.5" which is less than 0.5 inch to actual size I want to print.
Do anyone can suggest the solution to fix it?
