Printed banner vs applying vinyl
Discussion in 'Digital Printing' started by Hog Wild graphics, May 10, 2011.
  1. Hog Wild graphics
    Hog Wild graphics Member
    307
    Apr 2, 2011
    texas
    I do a fair amount of banners. I currently have a 30" Roland but a lot f my multi color banners are 3 or 4 ft. I know a lot of you have crunched the numbers. What's the pricing benefit to printing a 3 by 8 vs applying vinyl and all that comes with it. Not to mention I can press print and work on another project.
    Thanks in advice
  2. cdiesel
    cdiesel Very Active Member
    3,515
    Jan 28, 2005
    Phoenix, AZ
    We haven't applied vinyl to a banner in years.
  3. sghobbies
    sghobbies Member
    305
    Jan 18, 2008
    Adel, GA
    I can't remember the last time I layed vinyl on a banner. I still have pre grommeted rolls that are probably 4 years old...:( Maybe I need to make a few just to clear those rolls out.
  4. MR. Graphics
    MR. Graphics Member
    76
    Your immediate benefit is less labor. Your second benefit is your client can receive a full digital color printed banner for the same cost or less. Our cost per sqft for a printed banner is far less than what it would be for a multi color vinyl installed banner. If you are trying to justify buying a printer, a printer will open up more capabilities, you need to be able to keep that printer busy to offset the cost of running/maintaining that printer. IE INK, heads, calibration, printer payment/cost, electricity, space and if you start printing on regular vinyl the cost of a laminator and the materials associated.
    If you can run a paid print job every other day atleast, you won't regret getting a printer. do your research before you buy a used printer, I learned the hard way. Get someone who has had experiance with printers to help you out with the purchase / inspection of the used printer.
  5. cdiesel
    3,515
    Jan 28, 2005
    Phoenix, AZ
    Ha! We sold a bunch of pre hemmed banners that we had sitting around forever awhile back. Figured we were better off selling them than fighting putting vinyl on them.
  6. HulkSmash
    HulkSmash Major Contributor
    8,159
    140
    63
    Sep 10, 2010
    Denver.
    i have a customer who has a massive BBQ stand. She wants ALL her banners to be BRIGHT yellow, with cut vinyl. Needless to say she pays almost triple for them. and order 6 at a time.
  7. Custom_Grafx
    Custom_Grafx Very Active Member
    1,637
    2
    I read here not long ago that there is a gold mine to be made in renting out those babies. Put on "happy birthday" and the such and off you go.
    50% commission please for my suggestion.
    I should be able to get a soft serve in a year or two if you market yourself right with all my royalties :D
  8. boxerbay
    boxerbay Active Member
    938
    71
    28
    Nov 25, 2010
    Darkside of the Moon
    Depends on the banner.
    If like Colorado say they want a solid yellow with simple large text in red that says OPEN then cut vinyl mounted to yellow banner is going to last longer and probably be cheaper to produce BUT you charge it as a premium "NO FADE" banner.
    If they have 10 lines of 1" text then print it as the weeding and mounting time will kill you.
    PS: get a bigger printer.
  9. SightLine
    SightLine Very Active Member
    Only time we still do cut vinyl on a banner is if it's something like single color large text or if the customer wants some solid color banner with a a single color text. If solid color we just call a local supplier here in town and order the prefinished color blank to size. Anything else we totally run in house of digital print roll stocks.
  10. insignia
    insignia Very Active Member
    Your direct cost in manufacturing the banner is significantly less than cut vinyl once you factor in labor. And because it's full color, you can sell it at a bit of a premium because of it's perceived higher value. Plus, printing frees you up to do other things. We can print 10 banners in the time it takes to make one with cut vinyl, and sell them for more money. And while we're printing those 10 banners, we're figuring out other ways to make money.
    Really, the same thing applies to just about anything, not just banners. Yard signs, vehicle magnets, traditional signs, etc.. Printing reduces your labor and direct overhead in a job, frees you up for more things, and produces a higher valued product (most of the time anyway).
  11. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    I friend of mine tryed that at his shop. BIG HASSLE! At first no deposit and every banner came back either ripped up, folded up or just in a wadded up mess. Then he started getting a deposit and that was the end of that, no one want to mess with a $50 deposit on a happy B-Day banner.
    So THERE IS NOT big money in renting banners.
