Printer installation question?
MCV
I just purchased a new computer running windows 7 64bit home prem.
I installed Omega 4.0 with no problem but when I am trying to add a vinyl printer the dialog is only giving me an option of local to install from. The remote and network tabs are not there and I need the network tab to install the FX.
Did I install something wrong?
MCV
one more question not sure if this might be causing the problem. Orginally I had Omega 3.0 then upgraded to 4.0. Do I need to install 3.0 first on the new machine then upgrade to 4.0?
Any help would be greatly appreciated.
Tony Teveris
You do not have to install 3.0 first but it sounds like you installed a Design Station or at least your security key is configured for a Design Station. Do you have more than one security key? did you use the wrong one?
