Printer Not Recognized
netsol
BUT KEEP IN MIND
the router does DHCP fuctions. it will keep giving out IP addresses in the wrong subnet, unless he changes the router's setting.
DEPENDING ON THE FIRMWARE (instruction set the router runs) it will probably not devices in the WRONG SUBNET to be ROUTED (to the internet) and may keep the devices from seeing each other
THIS IS WHY I SAID it doesn;t make sense to use a router as a switch UNLESS YOU UNDERSTAND THE MANY PROBLEMS YOU CAN CAUSE YOURSELF
BrianK
I finally got it figured out. I changed the IP addresses like everyone said and it's working great! THANK YOU to everyone for all the help.
