Printing a flourescent orange
Discussion in 'Digital Printing' started by OCsteve, Dec 19, 2009.
  1. OCsteve
    OCsteve Member
    57
    1
    We are trying to create a decal that will match the orange of a water cooler. The color gamut on our Mimaki JV 3 will not allow us to "hit" the orange we need which is critical. This was a rush job for 16 decals that could into and order for 2500 if we can find a solution. Our solution was to use an orange vinyl to get a passable match. The second part of the problem was that the decal had a gray gradient which eliminated the use of colored vinyl. We were also required to use a matte laminate to reduce glare.
    Our solution on the 16 rush decals was to print the full color file, remove the non-matching orange with our cutter, mount the remaining graphic on orange vinyl, laminate the whole shebang and then contour cut the decal to size. It looked great but the price tripled with the additional material and labor involved.
    Any ideas how we can produce/create a more vibrant orange on our JV 3?
  2. Grafix USA
    Grafix USA Member
    302
    I'd check Stouse. I bet they can match it for the large order. Explain to the customer about spot printing and that it can't be achieved exactly in a short run digital print. You'll get closest by using RGB and tweaking the colors manually. Make sure you write down your codes once you get an acceptable color.
  3. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    Impossible. Period.
  4. iSign
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    DON'T EXPLAIN S#!T... TAKE THE MONEY, SUB IT OUT... MAKE OTHER MONEY WHILE SOMEONE ELSE MAKES YOU THAT MONEY :Big Laugh
  5. Grafix USA
    Grafix USA Member
    302
    He's talking about a first run of 16 decals. I don't think anyone is going to sub that out. I would mock up a "close" match and explain why it won't match exactly until the larger run through Stouse, etc.
    I'd start with RGB color of 255-69-0 and tweak it from there.
  6. OCsteve
    OCsteve Member
    57
    1
    Thanks guys. I will check with Stouse. I like the idea of subbing it out since the color match is critical.
  7. jiarby
    jiarby Major Contributor
    4,513
    you would have to silkscreen flourescent ink as a flood coat... essentially making your own sheet vinyl.
    You cant print a color outside your gamut. That' why they use the work "outside"!!
  8. CheapVehicleWrap
    CheapVehicleWrap Very Active Member
    3,943
    1
    Those Hooters people are hard to please :)
  9. Mosh
    Mosh Major Contributor
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    Can you post up the design, that might help formulate a solution.
  10. ZsVinylInc
    ZsVinylInc Member
    310
    Am I missing something here....why not just print, lam, cut and mask the logo or design with out the orange background and if they are worried about being able to apply them that way and not get any bubbles then do it on 3165 RA or IJ35C.
  11. OCsteve
    OCsteve Member
    57
    1
    Mosh - Sorry I can't post the design due to a confidentiality agreement. Client is rather paranoid.
    ZsVinylInc - We thought of that but without the orange there would be seven separate pieces being sent out to people to install that probably have never touched vinyl in their lives.
  12. ZsVinylInc
    ZsVinylInc Member
    310
    OCsteve I guess I am still missing something without seeing the design but if you mask all seven pieces under the same single piece of masking then it is only one item....Well just thought it might be a suggestion to help you with your problem....I am out of ideas except to sub it out. Happy Holidays and wish you the best of luck on this project.
    Big Z
  13. astro8
    astro8 Active Member
    778
    17
    18
    May 23, 2009
    Sydney, Australia
    You'll have to sub it out. Only way to print a proper orange is with orange ink (GS6000).
  14. Si Allen
    Si Allen Very Active Member
    2,146
    1
    Sounds like a job for silk screening! Won't be much profit in 16 pieces ... but iof you get the 2500 piece order...then lots of $$ to be made!
  15. ShawnLVESP
    ShawnLVESP Member
    160
    A lot of people are saying to sub the job out. But how does that sub company do it. What are they doing to get the right results. What type of machinery do they have.
    thanks
    I see screenprinting mentioned and using that specific color ink mentioned above. is there any other way.
  16. Mosh
    5,809
    41
    48
    Oct 19, 2009
    Nerbaska
    It is only 16 prints. Are they 4 inch prints or 4 feet? The customer is NOT always right, I think you are making this too hard, just tell them the color can not be matched unless they want to spend lots of $$$ on 16 decals for some coolers. Don't be scared to say you can't do something. I used to tell every customer "YES WE CAN", alot of the time I lost money just to do it! Now I tell them this is what I can do, if you don't like it call Joe Blow down the road. Alot less stress and guess what, most customers are happy with what we can do.
    BTW, I here all the time "if you can do these now in a rush we will order 1,000,000 of these later from you"
    Yeah right, don't be a sucker.
  17. heyskull
    heyskull Very Active Member
    1,668
    15
    38
    Sep 2, 2007
    UK
    Don't even start to believe this job will make you $1,000s
    This sounds like one of those customers wanting the nearly impossible for peanuts.
    I think you have stumbled already by giving this customer a product!
    He is going to turn round and ask for an extra 20off and you will never see him again!
    Nothings impossible for the right money.
    SC
  18. OCsteve
    OCsteve Member
    57
    1
    Thanks for all your input. I am in contact with Stouse to see if they can match the orange. The original 16 have already been produced and we did really well on this as we charged $600 for the color matching time involved an $18 each for the 12"x18" decals.
    I am not worried about the customer going elsewhere if we can find a solution. We do a lot of prototype work for this client and they never hesitate paying us for our time. The big issue, in addition to matching the color, is price. $18 each for the end user will not fly. If they were able to use the orange we could print the price would have been $6.50 each and this would have been a nice job this time of year. Generally, the middle of December to the middle of January is slow.
