Printing advice needed
Discussion in 'General Signmaking Topics' started by Zambookajoe, Nov 21, 2010.
  1. Zambookajoe
    Zambookajoe Member
    254
    1
    18
    Jan 11, 2009
    Ontario Canada
    I need to print 2 signs on clear vinyl using my jv33, I need to install those 2 prints to some alupanel boards that are already covered with 3m reflective engineer grade prismmatic white.
    my question is should I double hit the print to get a better result,( like doing a illuminated sign) or should I be fine with a single hit print.
    I do not have enough 3m printable reflective in stock, so this is my only option.
    any advice appreciated
  2. gabagoo
    gabagoo Major Contributor
    5,724
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    would not a double hit make the lettering less reflective?
    I have printed single pass on reflective with good results.
    If you are not sure just print 2 small pieces of clear and apply to the board to see the end results.
