Printing directly from Illustrator
I just recieved my Aurora Graphics Sign Blanks and am trying to contour cut. I was wondering if I can cut directly from Illustrator 8.0.
Any help is as always greatly appreciated.
Fred Weiss
The answer to that would be: Can you cut and print from Adobe Illustrator now? If you can do that then the Aurora Sign Blanks will also work. If you can't then they won't.
They are simply saved job files and will work in your system as you normally would use it.
