Printing Directly to .030 Polystyrene?
Discussion in 'Digital Printing' started by TheSellOut, Feb 10, 2010.
  1. TheSellOut
    TheSellOut Very Active Member
    1,355
    Has anyone tried printing directly to .030 polystyrene from their solvent printer?
  2. Circleville Signs
    Circleville Signs Very Active Member
    2,140
    11
    38
    Sep 30, 2009
    Circleville, OH
    No, but I've heard of people doing it - you have to watch it like a hawk. Headstrikes are legitimate possibility.
    Gary
  3. bluemedia_Ryan
    bluemedia_Ryan New Member
    2
    We have printed some on our Turbojet, seems to work ok .. but the inks in the turbo are pretty aggressive.
    Id say the biggest issue with printing on poly would be the ink drying time.
    We mainly run our poly on the PressVu UV machine.
  4. gabagoo
    gabagoo Major Contributor
    5,729
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    I have tried it and it works although as stated earlier, keep your hands ready for an immediate stop of the printer if the material somehow gets free from the side bars holding it down. I cant imagine the damage to the head if it struck the side of 030 styrene......not much give.
  5. BigfishDM
    BigfishDM Merchant Member
    5,019
    418
    83
    Jun 22, 2009
    All Over
    Ultraflex has some good printable styrene
  6. TheSellOut
    1,355
    Do you now the product name and where to get it? TIA
  7. Malkin
    Malkin Very Active Member
    2,188
    16
    38
    Feb 11, 2009
    Augusta, ME
    I have printed on the Sihl DuraSOL film. It's a semi-rigid PVC with a couple different weights available. It has a really nice satin finsh and the print look great. A little pricey though for some types of work.
    There are other semi-rigid PVC films that are cheaper and would be a better alternative to direct printing of styrene.
  8. Mochistlan
    Mochistlan Member
    36
    what printer do you want to use
    Hello what printer do you want to use to print the styrene.
    what inks do you use.
    you have to turn off the heat on the pre area and printing area, then you have to use the front take up to have tension to avoid any bulk on the printing area so avoid head strikes then heat the dryer high to begin drying the ink.
    you will have to make a special profile for the styrene.
    I hope this helps
  9. phototec
    phototec Very Active Member
    3,199
    22
    38
    May 23, 2008
    Belton
    "heat the dryer high"?
    What does this mean?
  10. Mochistlan
    Mochistlan Member
    36
    dryer plate
    increase the dryer to max temperature to dry the ink. how many heather plates do your printer have.
  11. Banners Signs Etc.
    Banners Signs Etc. Active Member
    609
    Sep 21, 2011
    Kentucky
    just be careful that the heater doesn't make the material bow and cause head strike when you start out
