Printing Double Sided on the JV5
Discussion in 'Mimaki' started by particleman, Jul 14, 2009.
  1. particleman
    particleman Member
    475
    31
    28
    Feb 1, 2008
    IN
    We are really fighting our JV5 trying to print double sided. This was never an issue on the JV3. When you goto print the 2nd side the printer will not start in the same spot every time. This makes it impossible to align the 2nd side. Is there a setting to force the printer to start at the same spot every time???
  2. Case
    Case Member
    378
    7
    18
    Jul 21, 2004
    IN
    When doing a double-sided banner on the Mimaki JV5, go in to Setup, Feed Method and set it to "Normal" to turn off the Media Encoder. That will keep it from moving and not starting at the spot you want it to...
    Case
  3. particleman
    particleman Member
    475
    31
    28
    Feb 1, 2008
    IN
    Case, that worked perfect
    Thanks!
  4. ast
    ast Member
    55
    Hi just want to ask if we can also do double side print with jv33?
  5. Case
    Case Member
    378
    7
    18
    Jul 21, 2004
    IN
    yes, you can...
    Case
