. Is this a head alignment problem? or something else?
I'm new to adjusting the head alignment, how do you check mechanical and electronic adjustments.
Actually, the alignment on the Jr's can be a pain.
You will need a Service Manual and some patience or luck.
There is a ratchet type system, where you loosen the set screw and raise or lower the ratchet wedge.
