DarkSideofOZ
So I recently got this printer, which the seller told me had merely dried up print heads as an issue. (which turned out to be false) I replaced both heads and the black/blue one refused to work. after some reading/troubleshooting, I traced it down to a bad C4131 transistor on the main board. Now both heads are firing. Weee!!
So last night I did the alignment and bidirection calibrations, then I got Versaworks installed, updated to 5.3.2. I talked to the gentleman I got the printer from and he told me the roll of paper that I got from him and was using, used the GPPG glossy photo paper ICC profile. So I set that one and tried to print and this is the result:
[video=youtube;OuWdpGRl8Yc]https://www.youtube.com/watch?v=OuWdpGRl8Yc&feature=youtu.be[/video]
As you can see the ink doesn't adhere, and looks to just pool up on the paper. The temps were correct on the printer, and I can't imagine that paper needing a higher temp.
Any ideas on what my issue might be?
