Printing on magnetic material with a xc540
Discussion in 'Roland' started by eco-saul, May 12, 2009.
  1. eco-saul
    eco-saul New Member
    3
    Hey guys, first post here :)
    I'm having a bit of trouble getting a decent print on magnetic material with the soljet. Anybody have any suggestions? I'm using versaworks and printing on Magnum Magnetic's 20 mil glossy. I wish I could post a scan of the print, but I've used about 15 different profiles and get very similiar/cr*ppy results. Looks kind of over-spray meets over-saturation. I've ran the usual calibrations and even called Roland, they won't help because they don't recommend printing on magnets :(
    Thanks!
  2. Tim Aucoin
    Tim Aucoin Very Active Member
    I've had no luck printing on magnets on my 540... similar results that you are experiencing. I made life easier for myself now and simply print on vinyl and use the Big Squeegee to mount onto magnetic. Works like a charm. I charge more and go home frustration free at the end of the day!
  3. DRamm76
    DRamm76 Member
    496
    1
    I have a lot of customers that use GMI's Printable Magnetic and have had some success but it still has a slight "bleeding" look it. The best results still come with printing on vinyl and mounting on to the magnetic. I know a customer who has made a FORTUNE printing onto Oracal from Versaworks on the VP-540, mounts it onto magnet and runs it through his Graphtec Flatbed cutter..Perfection everytime!
  4. eco-saul
    eco-saul New Member
    3
    That's is what I've done in the past as well. The supplier has a profile for the VP540, but not the XC540. Just wanted to see if any XC's had any luck out there.
  5. DRamm76
    DRamm76 Member
    496
    1
    MCVP will work just fine
  6. Gino
    Gino Premium Subscriber
    33,288
    2,321
    113
    Jun 7, 2006
    PA
    Welcome from PA......................
  7. vectorterrorist
    vectorterrorist Member
    152
    I'm getting ready to start doing some magnetics sand I have a roland vp 540 will my cutter be able to cut through this with a 60 degree blade one I have mounted my vinyl on top of the material- want to know the most effective process
  8. eco-saul
    eco-saul New Member
    3
    Mcvp ?
  9. Pacific Coast Sign
    Pacific Coast Sign Active Member
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    Hi Eco-saul - Give me a call if you have questions, I service Seattle.
  10. gps-hi
    gps-hi Guest
    V-terrorist,
    The VP will choke trying to cut the 30mil (vehicle weight), but I haven't tried the 20mil.
    In fact, when I print mags on the mp540 I've gotten in the habit of remove the blade to prevent unwanted scoring of the print.
  11. The Big Squeegee
    The Big Squeegee Major Contributor
    4,957
    107
    63
    Oct 10, 2005
    Lawton, OK, USA
    Welcome from OK.
