Question Printing on magnetic roll
Discussion in 'Mimaki' started by kbrys, Dec 3, 2018.
  1. kbrys
    kbrys New Member
    5
    May 22, 2009
    Illinois
    Has anyone tried printing on a roll of magnetic material in a Mimaki UCJV300-160? It appears only the back plate will cause an issue that I could cover with a thin PVC sheet.
    Kerry
  2. flyplainsdrifta
    flyplainsdrifta Active Member
    583
    115
    43
    Oct 13, 2017
    ct
    I use 030 styrene taped down on all sides to cover the pre heat platen on my roland. works like a charm. you just want to be CERTAIN you have it down really well. the last thing you want is to have that thing suck into the pinch rollers and into the carriage path. cause that is a good time for no-one.
  3. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,310
    812
    113
    Aug 2, 2011
    Denver, CO
    If you get a head strike on vinyl, the vinyl usually bunches up and the head stops when it senses this. You run a cleaning cycle to recover the nozzles and then keep on printing.
    If you get a head strike on magnet, all of the force goes into the head because the magnet doesn't budge and is much more rigid. This breaks the head and those heads cost about $4000 each.
    • Informative Informative x 1
  4. clarizeyale
    clarizeyale Member
    176
    42
    28
    Aug 25, 2016
    SF Bay Area
    different printer but I made a little thing for this issue once I saw this video.
    we print magnets on the flatbed now....
  5. Sindex Printing
    Sindex Printing Member
    158
    39
    28
    Nov 17, 2018
    Sparks
    • Like Like x 1
  6. Darryn
    Darryn New Member
    6
    1
    3
    Aug 8, 2016
    Canada
    On my Roland I just attached self-adhesive velcro (fuzzy size only) to a strip of magnet and placed that on the backplate. Keeps the magnet from getting too close and it works quite well. I attached it to magnet so that I could easily remove if needed but have had it there for a couple of years.
  7. Scott Sneddon
    Scott Sneddon New Member
    15
    1
    3
    Oct 24, 2018
    Layton Utah
    Brilliant
