Printing on Mesh Material
Discussion in 'Hewlett Packard' started by Renato Pinto, Oct 4, 2018.
  1. Renato Pinto
    Renato Pinto Graphics Manager
    64
    12
    8
    Mar 10, 2018
    Kansas
    Hey guys,
    We run an HP 560, we just bought a roll of key mesh material. There's no profile for it on HP so i just used a generic one.
    However, when printing, it is having horizontal streaks on the print. It doesn't look like the printhead is hitting the substrate but that is happening in the curing area.
    Any idea of whats going on? How to fix it? I'm assuming decreasing temperature and increasing the vaccuum but i was hoping somebody knew before i ruined more material.
    Thanks!
  2. Chasez
    Chasez Member
    420
    39
    28
    Jan 6, 2014
    canada
    Can you share a photo of the issue?
    Chaz
  3. Renato Pinto
    64
    12
    8
    Mar 10, 2018
    Kansas
    Here's some images.
  4. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    That doesn't really look like it's rubbing, but it could be hitting the heater. Next time you print, look up and into the heater platen. If it is rubbing to top, then lower the temperature in like 4 degree increments or use the take up reel.
    If it's not rubbing, then that sucks. Maybe someone else will know.
  5. Nickprints
    Nickprints Member
    50
    6
    8
    Aug 20, 2018
    Ma
    Looks like possibly the backing is getting wrinkled off causing bubbles in the material because the backing is getting suction but not the top mesh material. being that its a new machine it might not be dirty enough to cause darkening where the material would be rubbing against the head. Try to peel back the liner a couple inches and taping the actual finished mesh to the empty takeup core (not the backer)
  6. flyplainsdrifta
    flyplainsdrifta Active Member
    585
    116
    43
    Oct 13, 2017
    ct
    no that is definitely bumping up and hitting the heaterr on the inside, I've seen that many a time. throw that boy on the take-up and you should be all good.
