printing on styrene
Discussion in 'Materials' started by evie, Mar 6, 2014.
  1. evie
    evie Member
    137
    Jun 26, 2010
    riverside ca
    Can I print .030 styrene on my epson gs6000?
  2. artbot
    artbot Very Active Member
    3,164
    12
    38
    Feb 18, 2010
    Houston TX
    clear it lightly with CAB acrylic (krylon clear if it's a small piece) and you get decent results. no heat or it will buckle. sherwin williams dull rubbed effect will match the original styrene finish.
  3. mpn
    mpn Active Member
    740
    22
    18
    Aug 6, 2011
    Location
    Artbot, what do you use to apply the coating, roller,spray, brush? Best way you've found? Sounds like a good project for the down time.
  4. Donny7833
    Donny7833 Member
    204
    Nov 6, 2006
    Bluffton, SC
    I've printed .020 sheets on mine with head set to high, I would think there's enough clearance to run .030, but I would feed from a table and out to another table. I used Onyx with Oracal 3651 profile uni, heat set at 37 pre 34 print and 34 post. Image quality is pretty darn good. Be aware that you will get some static misting in open white area's, static tinsel helps, but humidity around 40% will really help. Best of luck.
  5. mpn
    mpn Active Member
    740
    22
    18
    Aug 6, 2011
    Location
    Just straight styrene, no coating?
  6. Donny7833
    Donny7833 Member
    204
    Nov 6, 2006
    Bluffton, SC
    Straight styrene. Print grade however, I was paying around $12 a sheet for 50x100.
  7. mpn
    mpn Active Member
    740
    22
    18
    Aug 6, 2011
    Location
    Thanks for the info Donny. Now I have to try it :Big Laugh
  8. artbot
    3,164
    12
    38
    Feb 18, 2010
    Houston TX
    i spray it. keep in mind that styrene can't handle a hot solvent so a fine layer with minimal to no retarder is best.
    you can print direct but the image won't be a fine. just depends on the distance
    viewed.
    the infeed/outfeed is another issue. how big are the prints? if they are 4x8 there are several tricks to getting the material through the printer.
  9. mpn
    mpn Active Member
    740
    22
    18
    Aug 6, 2011
    Location
    The job I want to experiment with would be cut down to 3x3 round cornered finish. The way I do them now is 12x24 sheets so the job is flexible in size.
    Thanks Artbot.
  10. Donny7833
    Donny7833 Member
    204
    Nov 6, 2006
    Bluffton, SC
    I disagree about the image not being fine. We were printing table tents, cooler tags and shelf talkers for a local liquor distributor, scoring them on our Summa (roller table front and back), then peel them out of the styrene . Full color, some with photos and you could scrutinize them.
    They eventually bought an Oki Data and brought that work in house. What we gave the client looks as good or better than what they print.
    Wanted to mention that if you need a photographic image and your running Onyx, get the PVC 10 profile from Grimco. Really nice print, but slow.
