BlueRidgeSignSupply
Print Manager
Hello,
Been around the site a long time, lurking mostly.
I've been printing for about a solid year now, and I've been having a hell of a time with getting my white ink to print correctly.
The epson does white in layers. C(olor)W(hite)C or CW or WC, depending on how you want your layers.
Using the high pressure rollers, I don't seem to have any problem actually getting the inks to lay down, I just can't for the life of me get them to line up correctly. (So the white bleeds out where it's not supposed to be).
Because they don't line up correctly, even if I just wanted to print and cut white stickers - the ink isn't in the same place that the cut line thinks it is, so the cutlines are always off.
My predecessor spent a long time figuring it out, and he finally got it. But even using his files and the same materials (with no major changes to the printer or otherwise) I can't reproduce what he did.
Has anyone had this issue? With this printer? What'd you do to fix it?
